Please test your codes with new system driver on Vesta
This coming Monday and Tuesday (4-5 Feb. 2013), Vesta will be down for extended maintenance, to install the latest BG/Q system driver from IBM (V1R2M0). Eventually, this driver version will be installed on Mira. Please help ALCF and yourselves by building and testing your Early Science codes on Vesta after the upgrade, if you can. Let us know if something breaks.
Leave a Reply
Your email address will not be published. Required fields are marked *
